ID # not showing in edit mode
Quote from julie.stiles@fcso.com on June 21, 2024, 2:38 pmWhen the form is in view the erf # shows, however when you select edit to make changes to the form, the erf # is not available. How can I correct this to show the number? Screenshots are attached.
Quote from EricD on June 24, 2024, 4:09 pmHi @julie.stiles@fcso.com,
I usually see that happen if the field is a calculated column. Calculated columns, by design, only show on the display form. What type of column is the ERF # column?
Quote from julie.stiles@fcso.com on June 24, 2024, 4:45 pm@james
It is a counter column.
@james
Quote from julie.stiles@fcso.com on July 9, 2024, 5:06 pm@james
Hi - have you had an opportunity to research this problem?
@james
Quote from supportTeam on August 12, 2024, 10:21 amHi Julie,
This issue could happen if any form event actions are configured to update the "ERF #" column value on the edit form.
Please go to the list -> List Settings -> Crow Canyon NITRO Forms -> Advanced -> Form Event Actions -> Check if form event action is configured to update the "ERF#" column value.
Also, please let us know when this issue is happening, like on edit form load or any column value change.
Hi Julie,
Quote from julie.stiles@fcso.com on August 12, 2024, 3:50 pm@crow-canyon-support
Hello - this is happening when we are opening the form to edit. I checked the Form Event Action and it is not configured to update the "ERF#" column value.
Thank you!
Julie
Thank you!
Julie
Quote from supportTeam on August 13, 2024, 9:55 amHi - please send us the list template and the NITRO forms settings file to investigate this issue further.
To save the list as template, go to the list -> List Settings -> Save list as template.
Please refer https://help.crowcanyon.com/article/445/ article to export NITRO forms settings.
You can send us these files via email (crowcanyonsupport@crowcanyon.com).
Quote from julie.stiles@fcso.com on August 13, 2024, 4:31 pm@crow-canyon-support
Hello! Unfortunately, I am unable to access this part of the site. Is there another way to access the information?
Quote from supportTeam on August 15, 2024, 9:50 amThere is no other way, please ask the user who has full control permissions on the site.
Quote from julie.stiles@fcso.com on August 21, 2024, 5:11 pmHello - I just emailed the list template to crowcanyonsupport@crow-canyon-support
Thank you.
Thank you.
