Forum Navigation
Please or Register to create posts and topics.
Highlighting Required Fields
Is it possible to make all fields that are marked as required to be highlighted with a different color? I know they have an asterisk next to them, and I am aware of the "NITRO Forms: Change The Color Of Form / Columns Based On A Value Selected In The Form" article (https://help.crowcanyon.com/article/444/), but it isn't quite what we're looking for and given that we have multitudes of InfoPath forms to migrate over, utilizing a script that would have to be customized for each form isn't really a good solution for us.
Is it possible to alter the color of the fields themselves at all, preferably without having to use a script?
@amanda-pollard, do you need to only set the colors for required fields?
Yup! We're on-prem, if that helps or changes anything.
We are adding this option to the NITRO Form theme settings. We are targeting the first half of Q2 for release. Thank you for your feedback!
AmandaP has reacted to this post.
AmandaP
